Timing Test Suite
Wed Jul 16 17:44:50 UTC 2003
Bert wrote:
> Hi, in the RTEMS source direcrory
> c\src\lib\libbsp\sparc\erc32, there
> is a file named "times", it describes
> "Timing Test Suite Results for the
> SPARC Instruction Simulator BSP".
> Here are two questions:
> (1) The Timing Test Suite is the test
> sample c\src\tests\tmtests\tmoverhd
> or not? if not, how to get the
> Timing Test Suite?
The Timing Test Suite is the set of tests
under the directory c/src/tests/tmtests.
tmoverhd is just one of them. It's output
is used by those BSPs which want to fill in
the file coverhd.h with real values.
> (2) What is the difference between the
> results in file "times" and the ERC32
> timing data in the document "RTEMS SPARC
> Applications Supplement"?
Probably gather running against different versions
of RTEMS.  If they are old enough, it is also possible
that there is a difference because the simulator used
to be for a different clock speed ERC32.  The numbers
10, 14, and 15 Mhz come to mind but I don't remember
what the change was.
> Thanks a lot!
> Bert
> Óµ±§ÀËÂþ£¬³¢ÊÔ¼¤Ç飬¼ÓÈë¿¡ÄÐÃÀÅ®µÄ¼¤Çé½»ÓÑÀÖÔ°
> http://y.21cn.com
> 21CNÐÂÎÅÖÐÐÄ ÎªÄãËÑÂÞ×î°ôµÄ¶¼ÊÐÐÂÎÅ×ÊѶ
> http://news.21cn.com
> ¹ºÂòÓÊÏ䣬¶ÌÐÅ¡¢ÓÎÏ·¡¢¿í´øµçÓ°Ãâ·ÑÏí
> http://mail.21cn.com/huodong/0304/wlxs
> ÐÂÆØÉçÇø »ðÀ±ÍƼö£º½ñÄêÒ»¶¨Òª¼Þ³öÈ¥
> http://forum.21cn.com/forum/index.jsp?forum_id=45
