bootpc timeout on private network
Feng, Shuchen
feng at bnl.gov
Thu Jul 10 15:06:03 UTC 2003
Hi,
Did anyone boot RTEMS sucessfully via a private network instead
of a public one ? When the ethernet communication of Bootp/tftp
client/server is placed on a public network with an ethernet hub, I
was able to boot RTEMS. However, when the ethernet
communication of Bootp/tftp client/server is placed on a private
network (clinet machine to server machine, point to point), the tftp
downloaded the RTEMS image, However, I got the error message :
"BOOTP timeout for server 0xffffffff". Both public and private
setups reside on one PC (two ethernet card). To switch between
the public and the private network, I changed the IP address of
the Bootp/tftp client/server, the netmask, and the gateway in the
bootptab file. The domain name server was taken out of the
bootptab file for the private network. Did I miss other steps ?
I ran a simple bootptest client on the private networked bootp server,
and it worked fine. On the same private network setup, I was able to
use ftp/nfs to run vxWorks application.
Thanks in advance,
Kate
P.S. : The attached is the capture of the boot process, which shows
the IP address of the provate network.
Copyright Motorola Inc. 1988 - 1999, All Rights Reserved
PPC1 Debugger/Diagnostics Release Version 4.5 - 09/24/99 RM01
COLD Start
Local Memory Found =02000000 (&33554432)
MPU Clock Speed =333Mhz
BUS Clock Speed =67Mhz
Reset Vector Location : ROM Bank B
Mezzanine Configuration: Single-MPU
Current 60X-Bus Master : MPU0
Idle MPU(s) : NONE
L2Cache: NONE
Initializing System Memory (DRAM)...
System Memory: 32MB, ECC Enabled (ECC-Memory Detected)
SelfTest/Boots about to Begin... Press <BREAK> at anytime to Abort ALL
NetBoot about to Begin... Press <ESC> to Bypass, <SPC> to Continue
Network Booting from: DEC21140, Controller 0, Device 0
Device Name: /pci at 80000000/pci1011,9 at e,0:0,0
Loading: epics/crate1/bin/example.exe
Client IP Address = 172.16.1.2
Server IP Address = 172.16.1.1
Gateway IP Address = 172.16.1.1
Subnet IP Address Mask = 255.255.255.0
Boot File Name = epics/crate1/bin/example.exe
Argument File Name =
Network Boot File load in progress... To abort hit <BREAK>
Bytes Received =&896748, Bytes Loaded =&896748
Bytes/Second =&128106, Elapsed Time =7 Second(s)
Residual-Data Located at: $01F88000
Model: 000000000000000000000000000(e2)
Serial: MOT041642A
Processor/Bus frequencies (Hz): 333372448/66674564
Time Base Divisor: 4000
Memory Size: 2000000
Original MSR: 3040
Original HID0: 82
Original R31: 0
PCI: Probing PCI hardware
RTEMS 4.x/PPC load:
Uncompressing the kernel...
Kernel at 0x00000000, size=0x1d0de0
Initrd at 0x00000000, size=0x0
Residual data at 0x001d1000
Command line at 0x001d8000
done
Now booting...
Welcome to rtems-4.6.0pre2(PowerPC/PowerPC 604/mvme2307) on MVME 2300
OpenPIC found at C1000000.
OpenPIC Version ? (2 CPUs and 17 IRQ sources) at 0xC1000000
OpenPIC Vendor 0 (Motorola), Device 0 (Raven), Stepping 2
OpenPIC timer frequency is 8334057 Hz
Universe II PCI-VME bridge detected at 0xC1040000, IRQ 11
Universe Master Ports:
Port VME-Addr Size PCI-Adrs Mode:
0: 0x20000000 0x0F000000 0x10000000 A32, Dat, Sup
1: 0x00000000 0x00FF0000 0x1F000000 A24, Dat, Sup
2: 0x00000000 0x00010000 0x1FFF0000 A16, Dat, Sup
Universe Slave Ports:
0: 0xC0000000 0x01FE0000 0x80000000 A32, Pgm, Dat, Sup, Usr
Overriding main IRQ line PCI info with 5
Registering /dev/console as minor 0 (==/dev/ttyS0)yDEC Adapter found !!
DC2114x : driver has been attached
boDoCt2p1c1_4ixn i8t::0 :u3sEi:n2gD :n4eEt:w1oEr kI RiQn t1e0r fIaOc e1
1'0d0c01 'M
C1041000 .........
Bootpc testing starting
bootpc hw address is 8:0:3e:2d:4e:1e
