Error while installing binutils gcc gdb RPM's
Victor V. Vengerov vvv at oktet.ru
Sat Jul 26 15:01:23 UTC 2003
Probably, you have no root priveleges. You need root priveleges
to install RPM package.
Victor
Aditya wrote:
> Hi,
> In the KDE Terminal when i try to install the RTEMS c/c++ toolset I
> get errors as below:
> $ rpm -i rtems-base-binutils-2.13.2.1-2.i686.rpm
> error: cannot open packages index using db3 - Operation not permitted (1)
> error: cannot open packages database in/var/lib/rpm
> May I know what is the cause of this error, Im using linux mandrake 9.1
> Aditya
Victor V. Vengerov
OKTET Ltd.
Ulianovskaya st., 1, office 533, St.-Petersburg 198504 Russia
phone: +7 812 4284384(work),+7 812 9389372(mobile),+7 812 4281653(home)
