How to build Unix BSP ?
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Tue Jul 29 13:30:27 UTC 2003
On Tue, 2003-07-29 at 15:11, Cedric Aubert wrote:
> Hi
> I am just try to compile without --target wrong
> option.
> (../rtems-4.6.0pre3/configure --enable-posix
> --enable-cxx --disable-itron --enable-networking
> --enable-test --enable-rtemsbsp=posix
> --prefix=/opt/rtems/bsp-unix)
> And now configure run and finish correctly but when
> I call gmake all, an error was produce after compiling
> successully the directory tools/cpu.
> It try to compile the directory c.
> Sorry some compiler message is in french :-(
Pas de problème - My French is a bit rusty, but hopefully sufficient to
understand what's going on ;)
Could please you send me the "config.log" and "config.status", that
should have been produced at the toplevel of your build directory.
Ralf
