How to build Unix BSP ?
Ralf Corsepius corsepiu at faw.uni-ulm.de
Thu Jul 31 04:18:21 UTC 2003
On Tue, 2003-07-29 at 15:11, Cedric Aubert wrote:
> Hi
> I am just try to compile without --target wrong
> option.
> (../rtems-4.6.0pre3/configure --enable-posix
> --enable-cxx --disable-itron --enable-networking
> --enable-test --enable-rtemsbsp=posix
> --prefix=/opt/rtems/bsp-unix)
> And now configure run and finish correctly but when
> I call gmake all, an error was produce after compiling
> successully the directory tools/cpu.
> It try to compile the directory c.
> Sorry some compiler message is in french :-(
> Making all in make
> Making all in c
> /bin/sh:cd: c: Aucun fichier ou répertoire de ce type
> make: ***[all recursive] Erreur 1
> Any idea ?
I believe to finally have found the cause: A bug in RTEMS-4.6.0pre3's
toplevel configure script (actually acinclude.m4) I believe to have
fixed several weeks ago.
=> Please try pre4, I am confident the bug already is fixed.
Ralf
