gdb with rdgb support
Andrew Sinclair
andrews at elprotech.com
Thu Jul 31 05:31:08 UTC 2003
Hi there,
I have encountered the same issue with gdb 5.2. Has anyone resolved this
problem?
Instead I am using an older version at the moment, installed from file
i386-RTEMS-gdb-5.0-7.i386.rpm. (Can be found at
ftp://ftp.oarcorp.com/pub/rtems/snapshots/c_tools/gdb-5.0-7/linux_x86/RP
MS/)
It appears to work, although I am having problems loading debug symbols. I
have been running rdgb on the http network demo using the standard makefile
included in network-demos-4.6.0pre4.tar.bz2. I have added the following
lines after rtems_bsdnet_initialize_network () inside init.c:
rtems_rdbg_initialize();
enterRdbg();
I have been unable to identify where the debug symbols have been stripped
off from the executable. Does anyone know how to keep these symbols? I have
tried using the http.obj file produced in the build, however I cant get
links to source files correctly.
This is what I get when I remote debug to a machine at 169.254.100.112:
[andrews at store http]$ i386-RTEMS-gdb
GNU gdb 5.0
Copyright 2000 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you
are
welcome to change it and/or distribute copies of it under certain
conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for details.
This GDB was configured as "--host=i686-pc-linux-gnu --target=i386-RTEMS".
(gdb) setrpcmode sun
(gdb) setdaemontype rdbg
(gdb) target rtems 169.254.100.112
Attaching remote machine across net...
Connected to 169.254.100.112.
Now the "run" command will start a remote process.
(gdb) file o-optimize/http.obj
Reading symbols from o-optimize/http.obj...done.
(gdb) attach 1
Attaching program:
/rtems/tools/network-demos-4.6.0pre4/http/o-optimize/http.obj
pid 1
[Switching to process 167837703]
enterRdbg () at {standard input}:27
27 {standard input}: No such file or directory.
Does anyone know what I am doing wrong?
Kind Regards
Andrew Sinclair
-----Original Message-----
Sent: Thursday, 24 July 2003 10:02 PM
To: Rtems-Users (E-mail)
Subject: gdb with rdgb support
Hi,
I have some trouble compiling gdb with rdgb support.
Configuring with:
.../configure --verbose --target=i386-rtems --prefix=/usr/local/rtems
succeeds, but when entering:
$ gdb
.. yada yada ...
This GDB was configured as "--host=i686-pc-cygwin --target=i386-rtems"...
(gdb) target rtems target-name
fails undefined commands (and undefined target command).
I searched the archives a bit and found this thread:
http://www.rtems.com/rtems/maillistArchives/rtems-users/2000/october/msg
00010.html
Seemed exactly like my problem, but when attempting to configure with
--target=i386-RTEMS i get "Invalid configuration `i386-RTEMS': system
`RTEMS' not recognized".
I have patched the gdb-5.2 source with:
gdb-5.2-rtems-base-20030211.diff
gdb-5.2-rtems-cg-20030211.diff # not sure if this one is needed.
gdb-5.2-rtems-rdbg-20030211.diff
All successful.
Any suggestions?
While we are at the remote gdb-stuff: What is the prefered way to start an
Ada program on the remote and make it wait for the gdb-client before
starting?
Best regards
Per
PS: Sorry for that #$")!/&% footer, IT is still working on it
(idle-priority i guess).
IMPORTANT
The information contained in this e-mail is privileged and confidential
information intended only for the use of the individual or entity named
above. If the reader of this message is not the intended recipient, you are
hereby notified that any dissemination, distribution or copying of this
communication is strictly prohibited. If you have received this
communication in error, please immediately notify us by e-mail or
telephone.
Thank you in advance.
