build rtems-4.6.0pre2 applied pr369.???
Wed Jun 4 13:23:24 UTC 2003
David wu wrote:
> Hello all:
>   I got an error when build rtems-4.6.0pre2 applied
> pr369.
>   I have downloaded rtems-4.6.0pre1 source code from
> oar ftp site,
>   and then in rtems-4.6.0pre1 directory "gcat
> ../rtems-4.6.0pre1-4.6.0pre2.diff.bz2 | patch -p1",
>   , "cat ../pr369_fileio_sample.diff | patch -p1" ,run
> "bootstrap".
>   At last i use "./bit_rtems i386 pc386" to build
> rtems ,got an error showed detail below :
I am guessing that your autoconf/automake versions are not the
ones required by RTEMS.
>  gmake[6]: Entering directory
> `/home/administratorrtems/build-i386-rtems/i386-rtems/c/pc386/exec/libm
> isc/untar'
> /usr/bin/install -c -m 644
> ../../../../../../../rtems-4.6.0pre2/c/src/../../cpukit/libmisc/untar/unt
> ar.h ../../../../../pc386/lib/include/rtems/untar.h
> gmake[6]: Leaving directory
> `/home/administratorrtems/build-i386-rtems/i386-rtems/c/pc386/exec/libmi
> sc/untar'
> Making preinstall in fsmount
> isc/fsmount'
> Makefile:493: *** missing separator.  Stop.
> sc/fsmount'
> gmake[5]: *** [preinstall-recursive] Error 1
> gmake[5]: Leaving directory
> sc'
> gmake[4]: *** [preinstall-recursive] Error 1
> gmake[4]: Leaving directory
> `/home/administratorrtems/build-i386-rtems/i386-rtems/c/pc386/exec'
> gmake[3]: *** [preinstall-recursive] Error 1
> gmake[3]: Leaving directory
> `/home/administratorrtems/build-i386-rtems/i386-rtems/c/pc386'
> gmake[2]: *** [pc386] Error 1
> gmake[2]: Leaving directory
> `/home/administratorrtems/build-i386-rtems/i386-rtems/c'
> gmake[1]: *** [all-recursive] Error 1
> gmake[1]: Leaving directory
> gmake: *** [all-recursive] Error 1
> ERROR: failed gmake all.
> exit: Illegal number: ./bit_rtems
> /opt/rtems/bin:/usr/local/bin:/usr/bin:/bin:/cygdrive/c/winnt/system32:/cygdrive/c/winnt:/cygdrive/c
> /winnt/System32/Wbem:/cygdrive/c/PROGRA~1/ULTRAE~1:/cygdrive/c/Program:/opt/rtems-4.6.0pre2/bin
> Thanks
> _________________________________________________________
> Do You Yahoo!?
> Á÷Á¬ÍøÂçÊÀ½çµÄ¡°Ä㡱ÊÇË­£¿
> http://cn.rd.yahoo.com/mail_cn/tag/?http://cn.surveys.yahoo.com/cn_user_profile_study_may2003
