Makefile problem was Re: make fileio example???
    David wu
    rtemswq at yahoo.com.cn
    Tue Jun 17 07:30:46 UTC 2003
hi ,
I use gdb stub to debug fileio.exe ,trace into stat.c
function stat(), line 62 and find status == -1 .
62  status = rtems_filesystem_evaluate_path( path, 0,
&loc, _STAT_FOLLOW_LINKS );
63  if ( status != 0 )
watch path==/dev/hda
modify path value to /dev/hda1 or  /dev/hda2  ,status
== -1 yet.
and then i can see as below on pc screen
   ---unused dynamic memory:32157772 bytes ---
   hda result = 25
   hda1 result = 25
   hda2 result = 25
my computer have only one  4.3G harddisk ,fdisk and
formate/s by freedos command into only one fat16
partition.
thanks
		David
 --- Thomas Doerfler <Thomas.Doerfler at imd-systems.de>
的正文:> Hello David,
> currently I can only guess:
> I have grepped through the cpukit source tree for
> "RTEMS_INTERNAL_ERROR":
> cd <path_to_your_rtems_source_tree>/cpukit
> grep -r RTEMS_INTERNAL_ERROR *
> I found several references in "ide_part_table.c" and
> "ata.c".
> Maybe you can have a look at these sources to find
> out
> possible reasons for your error?
> Maybe the partition table is different to the way it
> is
> expected?
> Sorry, this is not much. Do you have a debugging
> possibility
> for the relevant code?
> wkr,
> 	Thomas.
> > Thanks to all,
> >   I have build fileio example,successfully.
> > I am sure ,after i make install rtems-4.6.0pre3,
> some
> > .c and .h files have not been installed,
> > just copy files to fileio example(ata.h ata.c
> > ata_internal.h fsmount.c fsmount.h
> > ide_controller.c),and modify some file, it looks
> like
> > ok,i can make out fileio.exe.
> > Bit another problem got out,when i boot my
> computer by
> > grub and run fileio example, I can see FILE I/O
> Test
> > Menu.
> >   But when i select "P->part_table_initialize" ,i
> got
> > message as below:
> >   hda result = 25
> >   i know "result = 25" is mean
> > ,but how to resolve this error???
> > Thanks
> > 	David wu
> > BTW,i am sorry for my poor english.
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler           Herbststrasse 8
> D-82178 Puchheim          Germany
> email:    Thomas.Doerfler at imd-systems.de
> PGP public key available at: http://www.imd-
> systems.de/pgp_keys.htm
_________________________________________________________
Do You Yahoo!?
流连网络世界的“你”是谁?
http://cn.rd.yahoo.com/mail_cn/tag/?http://cn.surveys.yahoo.com/cn_user_profile_study_may2003
