Makefile problem was Re: make fileio example???
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Mon Jun 16 19:30:17 UTC 2003
Hello David,
currently I can only guess:
I have grepped through the cpukit source tree for
"RTEMS_INTERNAL_ERROR":
cd <path_to_your_rtems_source_tree>/cpukit
grep -r RTEMS_INTERNAL_ERROR *
I found several references in "ide_part_table.c" and "ata.c".
Maybe you can have a look at these sources to find out
possible reasons for your error?
Maybe the partition table is different to the way it is
expected?
Sorry, this is not much. Do you have a debugging possibility
for the relevant code?
wkr,
Thomas.
> Thanks to all,
> I have build fileio example,successfully.
> I am sure ,after i make install rtems-4.6.0pre3, some
> .c and .h files have not been installed,
> just copy files to fileio example(ata.h ata.c
> ata_internal.h fsmount.c fsmount.h
> ide_controller.c),and modify some file, it looks like
> ok,i can make out fileio.exe.
> Bit another problem got out,when i boot my computer by
> grub and run fileio example, I can see FILE I/O Test
> Menu.
> But when i select "P->part_table_initialize" ,i got
> message as below:
> ---unused dynamic memory:32157772 bytes ---
> hda result = 25
> i know "result = 25" is mean RTEMS_INTERNAL_ERROR
> ,but how to resolve this error???
> Thanks
> David wu
> BTW,i am sorry for my poor english.
> _________________________________________________________
> Do You Yahoo!?
> Á÷Á¬ÍøÂçÊÀ½çµÄ¡°Ä㡱ÊÇË£¿
> http://cn.rd.yahoo.com/mail_cn/tag/?http://cn.surveys.yahoo.com/cn_user_profile_study_may2003
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd-
systems.de/pgp_keys.htm
