contiguous physical memory allocation
Salman unix at gofree.indigo.ie
Tue Mar 4 22:04:11 UTC 2003
> >hi guys,
> >i'm looking for a function in rtems which allocates contiguous physical
> >memory (somewhat similar to memalign in vxworks)
> As far as I known, RTEMS uses a flat memory model. It means the physical
> address is the same logical address and malloc should allocate
> contiguous physical memory.
One other thing though, I need to have the allocated buffer aligned as
well (so that it begins on a memory address evenly divisible by 8192),
any idea on how to achieve this?
thanks for the response,
Salman
