Building rpms (was Re: unable to make install under cygwin)
Kamen Penev kamen at penev.net
Wed Mar 12 20:09:18 UTC 2003
Ralf Corsepius wrote:
>This is correct. DESTDIR normally is empty, and is supposed to be
>provided from the environment if wanting to shift the root of
>installation tree. It typically is applied for building rpms, which
>temporary installs to a temporary directory.
Interesting. Is this documented? If not, can you please briefly describe
the procedure. I'd like to be able to distribute prebuilt RTEMS to my
coworkers.
Thanks.
Kamen
