rtems_task acting strange
Angelo Fraietta
angelo_f at bigpond.com
Thu Mar 13 21:48:44 UTC 2003
What BSP are you running?
Salman wrote:
>On Wed, 2003-03-12 at 13:37, Joel Sherrill wrote:
>>Salman wrote:
>>>Hi guys,
>>>I'm observing strange behavior when executing the following osif_init
>>>function.
>>>It gets as far as printing "were gonna startthe task 0 !!!!" (status = 0
>>>-> successful task creation) and waiting for return key.
>>>when I press return key, it goes mental, the screen either starts
>>>dumping infinite garbage, or I get a page of errors with heading related
>>>to thread error or something (i can't fully read it, cos system reboots
>>>straight afterwards)
>>>any idea whats going wrong ?
>>If osif_init() is an initialization task and an RTEMS Classic API task,
>>then it is falling off the bottom and that is a fatal error. So I think
>>the system is giving a fatal error. Try adding an
>>rtems_task_delete(RTEMS_SELF)
>>to the bottom instead of a return.
>>For sure the mq task at the bottom is also falling out the bottom since
>>you have commented out the infinite task body loop.
>I don't know whether it's my code, or a possible bug in rtems, but one
>thread always gets killed in middle of my program. Hence, I create a
>dummy "victim thread" named "RND0" so that it doesn't kill my main
>thread.
>>From my point of view, the following "RND0" thread, should not encounter
>any problems, regardless of what goes on in other threads. I'm not even
>producing any other thread with the same name and it still dies !
>For the moment, this approach of having a dummy "victim thread" is
>working for me, so i'm not keen on fixing it, but after my project is
>finished, I'll look into this :)
>rtems_task
>totest_task(rtems_task_argument args)
> while (1)
> printk ("still awake");
> rtems_task_wake_after(TICKS_PER_SECOND * 10);
>void testfirst()
> rtems_status_code status;
> rtems_id Task_id;
> status = rtems_task_create(
> rtems_build_name( 'R', 'N', 'D', '0'),
> 2, RTEMS_MINIMUM_STACK_SIZE * 2, RTEMS_DEFAULT_MODES,
> RTEMS_DEFAULT_ATTRIBUTES, &Task_id);
> printf("were gonna startthe task %i !!!!",(int)status);
> getchar();
> status = rtems_task_start( Task_id,
>totest_task,(rtems_task_argument)0);
> printf("we just did %i !!!!",(int)status);
> getchar();
>rtems_task Init(
> rtems_task_argument ignored
> printk( "Hello World\n" );
> getchar();
> testfirst();
> getchar();
> sci_init(0);
> getchar();
> IRM19_GenIf_unit_test_main();
> exit( 0 );
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
URL: <http://lists.rtems.org/pipermail/users/attachments/20030314/411e9b18/attachment.html>
