bit scripts
Angelo Fraietta
angelo_f at bigpond.com
Mon Mar 17 06:10:00 UTC 2003
I have built the pre-release with the following tools and was able to
run the ticker example using the latest binutils but using
gcc 3.2
gcc-3.2-rtems-20021114.diff
newlib-1.10.0-rtems-20021114.diff
newlib-1.10.0.tar.gz
It may, therefore, be something wrong with the latest GCC/newlib
Also, I am unable to get through to the RTEMS newsgroup. Is the email
server down or something?
Valette Eric wrote:
> Angelo Fraietta wrote:
>> Ok, this works. So there must be something that I have done wrong.
> Not sure. I send it because you asked as a prof that the tools and
> code might actually be OK.
>> Did you build this on your OSX machine and is this the pre-release?
> I build that on a PC running debian unstable... The compiler is
> configured as follow :
> /usr/local/rtems-ix86-dev-tools/bin/i386-rtems-gcc -v
> Reading specs from
> /usr/local/rtems-ix86-dev-tools/lib/gcc-lib/i386-rtems/3.2.1/specs
> Configured with: ../gcc-3.2.1/configure
> --prefix=/usr/local/rtems-ix86-dev-tools --target=i386-rtems
> --enable-threads --with-newlib --with-gnu-ld --with-gnu-as
> --enable-languages=c,c++
> Thread model: rtems
> gcc version 3.2.1
> Yes this is the 4.6pre1 release. Reading more carefully your mail, You
> seem to have confused me with another famous eric on this list : Eric
> Norum.
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
