bit scripts
Angelo Fraietta
angelo_f at bigpond.com
Wed Mar 12 22:56:26 UTC 2003
Valette Eric wrote:
> Angelo Fraietta wrote:
> Here you have a self contained floppy image containing ticker + my own
> bootloader + the ticker binary in the sample directory. Note that the
> floppy use the ticker.obj binary (before stripping)...
Did you make any modifcation at all the the BSP for yopurself?
I have built the example and as soon as it tries to start the task, I
get a rolling exception 6
What exception type is this?
Additionally, I have commented out all of the code within the task
function (leaving a while (1) loop) to see if was a stack overflow,
however, this did not work.
i.e
rtems_task Test_task(
rtems_task_argument unused
while (1);
I also only created one task and tested the result, which came back
successful
status = rtems_task_create(
Task_name[ 1 ], 1, RTEMS_MINIMUM_STACK_SIZE * 2, RTEMS_DEFAULT_MODES,
RTEMS_DEFAULT_ATTRIBUTES, &Task_id[ 1 ]
if (status == RTEMS_SUCCESSFUL)
printf ("Stack Size = %u\r\n", RTEMS_MINIMUM_STACK_SIZE);
puts("Starting Task");
/*status = rtems_task_start( Task_id[ 1 ], Test_task, 1 );*/
as soon as I comment out
The program will not run.
Any ideas as to why this one fails.
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
