(Fwd) Re: DOSFS bug fixes, IDE drivers and sample released
Angelo Fraietta angelo_f at bigpond.com
Wed Mar 19 00:10:41 UTC 2003
Thomas Doerfler wrote:
>Hello Angelo,
>the "sample" program is located in the patch filed in the gnat
>system as PR369. So if you go to
>http://www.oarcorp.com/cgi-bin/gnatsweb.pl
>and inspect PR369 and download/apply the patch and then look
>into c/src/tests/samples/fileio, you will see the sample
>application.
>BTW, you will also need PR368 and PR367 to get everything
>running (these PRs contain modifications for the DOSFS code
>and added drivers for PC386 and MBX8xx).
>wkr,
>	Thomas.
I have downloaded all the patches and performed the build, however, the sasmple is not being built.
I also configured with --enable-tests, but still the sample was not built.
I tried to build it using a makefile, however, I got a compile error unable to include /rtems/ata.h
I looked in the install directories, however, ata.h is not there (it is in the source directory)
Do I have to do something special in the configure to build this?
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
    Bernard of Clairvaux (1090 - 1153)
