4.6pre1 Makefile link libraries
Ralf Corsepius corsepiu at faw.uni-ulm.de
Wed Mar 5 04:19:55 UTC 2003
Am Die, 2003-03-04 um 23.08 schrieb Wendell Thompson:
> gregory.menke at gsfc.nasa.gov wrote:
> > Wendell Thompson writes:
> >  > For a C++ application with 4.6.0pre1, which link libraries need to be
> >  > listed in the Makefile?
> >  > The linker is complaining about even the C++ basics- operator new,
> >  > operator delete, etc. Amongst other things.
This indicates one of these
* not using <target>-rtems-g++ to link.
* not using make-cxx-exe to build the download-images
* not having a make-cxx-exe in your <bsp>.cfg
> > I think you may have gcc/binutils/newlib problems- which is possibly
> > related to your makefile issue.
I doubt this.
> These tools are from the OAR web site rpms:
> wentho at linux:/usr/local/rtems_tools_sources> rpm -q -a | grep m68k
> m68k-rtems-binutils-2.13.2.1-1
> m68k-rtems-c++-gcc3.2.1newlib1.11.0-1
> m68k-rtems-gcc-gcc3.2.1newlib1.11.0-1
> wentho at linux:/usr/local/rtems_tools_sources> rpm -q -a | grep rtems-base
> rtems-base-gdb-5.2-1
> rtems-base-binutils-2.13.2.1-1
> rtems-base-gcc-gcc3.2.1newlib1.11.0-1
> Is there something specific I should look for?
Ralf
