Port to Atmel AVR RISC processor
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Mar 6 00:18:21 UTC 2003
David Dudley wrote:
>Has anyone attempted to port rtems to the Atmel AVR chip family?
>Looks like I'm going to have a requirement for one, so if no one has ....
>well, its started.
>Got a question, or two before getting started, though:
>1. The "Porting" guide doesn't reflect the structure of the RTEMS directory,
>but rather, the 'build' directory, from what I've seen. Is there a document
>that describes the source directory, and what goes where (and where things
>are to start with??? )?
Please point out those differences so they can be fixed. The
rearrangement of the
source tree to separate BSPs and ":CPU Kit" many not be reflected. In
general,
you are looking at the directories:
cpukit/score/cpu/XXX
c/src/lib/libcpu
c/src/lib/libbsp
>2. How do the libbsp/libcpu directories get built into the "build" directory?
>It appears that files are actually copied from one place to the other -
>what/how are the files determined, and why didn't you just use symbolic
>links?
I will let Ralf go on this one. It really isn't as radically different
as it looks though.
>3. in the cpukit directory, is the file structure 'reflected' into the build
>directory somehow? ... and if so.... how?
Ralf.
>4. What "*.ac" files need to be modified to add the new architecture into the
>package?
I think this is in the archives but you will have to create libbsp/avr
and populate that.
The main ac scripts will be rtems-cpu-subdirs.m4
>5. Is newlib support a requirement? I now have a C compiler that efficently
>compiles code for the processor, but there isn't any runtime support, to
>speak of.
RTEMS includes a lot of POSIX support. newlib is a lot easier to use.
You can use other C libraries but not as easily. If you stick to the
Classic API
and no networking, the dependencies on a libc will be smaller. I recall the
AVR is a small CPU so you might find yourself disablining certain parts of
the tree for the avr.
>Thanks-
>David Dudley
