bit scripts
Thu Mar 6 21:33:28 UTC 2003
I hate to ask this at this point but what version of RTEMS
did you use to successfully run these tests before on this
same hardware?  I do not believe anything is wrong with your
tools or installation.  I am beginning to wonder if some
other change between the last one you tried and this
one are doing it.  Since the
You mention Linux and MacOS X.  Are the test results the same
when compiled from both environments?
See my comments below.
--joel
Angelo Fraietta wrote:
> Joel Sherrill wrote:
> > Ralf Corsepius wrote:
> >> Am Mit, 2003-03-05 um 22.45 schrieb Angelo Fraietta:
> >>> I placed the full console output for my attempt of the 4.6
> >>> prerelease on
> >>> ] http://www.quikscribe.com.au/downloads/rtems/BuildErrors.html
> >>> However, no-one has been able/willing to tell me what I have done
> >>> wrong so I am stuck.
> >> I don't see any error in your log-files.
> > I don't either.  It looks like your tools and RTEMS are building
> > completely.
> > I think I noticed that you built all the BSPs (no --enable-rtemsbsp
> > option).
> Is this supposed to be in the configure? I want pc386dx, however, I also
> built the pc386 to eliminate floating point library issues.
pc386 assumes the presence of an FPU.
pc386dx assumes no FPU.
> After the configure completed I did
> gmake RTEMS_BSP="pc386 pc386dx"
> This also built without logging any errors.
> > Which BSP are you trying to load, what PC are you using and how does
> I tested both the two I mentioned on a Pentium 200 (it ran samples fine
> from the old snapshot samples)
> > it fail?
> Ticker and unlimited cause an exception message to scroll all the time
> with both pc386 and pc386dx (run on Pentium 200)
Which exception is it?
> with the exception of unlimited built with pc386 which writes a message
> similar to the ones I built with the previous snapshot (message posted
> 28 Feb)
>    I get the message
>    TEST1: auto-extend disabled
>    TEST1: creating task 'aa00', number = 0, ide = 0a010002, starting
> with the exception that the screen becomes completely white after the
> word starting to the bottom of the screen.
> Angelo Fraietta
> PO Box 859
> Hamilton NSW 2303
> Home Page
> http://www.users.bigpond.com/angelo_f/
> There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
> There are those who seek knowledge to be known by others - that is VANITY
> There are those who seek knowledge in order to serve - that is LOVE
>     Bernard of Clairvaux (1090 - 1153)
