unable to make install under cygwin
Angelo Fraietta angelo_f at bigpond.com
Wed Mar 12 01:28:13 UTC 2003
Ralf Corsepius wrote:
>Am Die, 2003-03-11 um 23.46 schrieb Angelo Fraietta:
>>I am unable to make and install RTEMS under cygwin.
>>If I do a make all, RTEMS builds (the samples still don't work though);
>>however, if I do a make install, I get the following failure:
>>/usr/nin/install: cannot create regular file
>>//opt/rtems/i386-rtems/pc386/lib " no such host or network
>In which directory does this happen ?
ifrstly should have read
/usr/bin/install: cannot create regular file
I am in directory /develop/build
>>I believe the problem is that is is trying to go to //opt instead of /opt
>If this hold, this would qualify as a massive bug in Cygwin.
>>Is there anything special I need to do in the configure for cygwin?
>Basically it should be: Make sure all partitions are mounted binary and
>make sure your /bin/sh is bash (Former versions of Cygwin shipped ash as
>/bin/sh - I don't know about the current status).
How does one do this. I downloaded and installed the latest cygwin and
there was no sh in the /bin directory
This causes the configure to fail immediately
So I made a symlink from /bin/bash to bin/sh, howevere, this configured,
however, this made the build fail during the make all
So I copied sh.exe from my previous cygwin and this is currently
building, however, I will have to wait until the install takes place to
see what happens
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
    Bernard of Clairvaux (1090 - 1153)
URL: <http://lists.rtems.org/pipermail/users/attachments/20030312/ad64c1e8/attachment-0001.html>
