unable to make install under cygwin
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Mar 11 23:01:18 UTC 2003
Angelo Fraietta wrote:
> I am unable to make and install RTEMS under cygwin.
> If I do a make all, RTEMS builds (the samples still don't work though);
> however, if I do a make install, I get the following failure:
> /usr/nin/install: cannot create regular file
> //opt/rtems/i386-rtems/pc386/lib " no such host or network
> I believe the problem is that is is trying to go to //opt instead of /opt
> Is there anything special I need to do in the configure for cygwin?
I downloaded over the weekend to my home computer and did a
"native" Cygwin build without problems.
I think you are right that // is special in Cygwin. Can you tell
from the logs where it started to come from? I believe it is looking
for the host named "opt". :(
> Angelo Fraietta
> PO Box 859
> Hamilton NSW 2303
> Home Page
> http://www.users.bigpond.com/angelo_f/
> There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
> There are those who seek knowledge to be known by others - that is VANITY
> There are those who seek knowledge in order to serve - that is LOVE
> Bernard of Clairvaux (1090 - 1153)
