Problems setting up the libcpu directory structure
David Dudley rtems-users at StarBlade.com
Fri Mar 14 19:06:13 UTC 2003
Unfortunately, I had already checked that.  RTEUS_CPU_MODEL is assigned to
ATmega128, and when you run the make program, in the preinstall
configuration, you can see the definition of 'RTEMS_CPU_MODEL=ATmega128'
being passed to the configure script.
Any other ideas?
David Dudley
On Friday 14 March 2003 12:09, Joel Sherrill wrote:
> David Dudley wrote:
> > I've run into a little problem setting up the libbsp/libcpu directory
> > structures for the AVR chip.
> > I defined a structure like this (which is a mirror of the structure of
> > the 'sh' directory):
> > libbsp
> >   + avr
> >       + DL16  (our particular board name)
> > libcpu
> >   + avr
> >        + ATmega128  (chip on the board)
> > Inside the ATmega128 directory I have the drivers for the console, clock,
> > rtc, etc....
> > Inside the DL16 directory I have the drivers for our specific board
> > implementation.
> > The bootstrap program runs with out any errors, and builds the links into
> > the avr directories.
> > OK, now when you do a configure, things go fine.  No errors or anything
> > else. When you run make however, the make starts building the package,
> > making the directories and copying files around, and eventually gets to
> > the libbsp and libcpu directories.  The libbsp directory looks like its
> > defined OK, and gets copies of the stuff from the avr/DL16 directory,
> > however, when the make moves to the libcpu directory, it creates a
> > directory called ATmega128 (right?), and then tries to do a preinstall on
> > the DL16 subdirector, which of course, doesn't exist.
> > Whats wrong?  I have looked and looked, and I've built the directory
> > structure and configure.ac files in what it looks like is the right form.
> Without looking at source, I would say that your RTEMS_CPU_MODEL is set
> to the
> name of the BSP (DL16) not the same of the CPU model (ATmeage128).
> Doublecheck
> the dl16.cfg file in make/custom.
> > Also, under the libbsp/avr directory, is it OK to have just our board
> > name directly at that level, or wouldn't it be better to list it as a
> > subdirectory of the company name (such as "StarBlade/DL16")?
> It might make a nice organizational aid but since no one has ever tried
> doing
> that I am prone to guess that something will depend upon libbsp/CPU/BSP
> being
> the structure.  So far, putting BSPs into CPU subdirectories has
> prevented
> clutter.  If you want, call the BSP starblade_dl16 and have the best of
> both
> worlds.  A more unique name and no worries of a subdirectory.
> > David Dudley
