Problems setting up the libcpu directory structure
David Dudley rtems-users at StarBlade.com
Fri Mar 14 20:09:54 UTC 2003
OK, found the problem with that.  I had inadvertently (my mistake) copied the
wrong Makefile.am from the wrong directory.  Its taken care of, now.
Next Question:
Is there a document, or description available  that explains the RTEMS
configuration directives? or a document on how to build the Makefile.am
files?
On Friday 14 March 2003 13:34, Joel Sherrill wrote:
> David Dudley wrote:
> > Unfortunately, I had already checked that.  RTEUS_CPU_MODEL is assigned
> > to ATmega128, and when you run the make program, in the preinstall
> > configuration, you can see the definition of 'RTEMS_CPU_MODEL=ATmega128'
> > being passed to the configure script.
> Before you move on to the BSP, try building the following
> configurations:
> + Multilibs - example configure command
> ../current/configure --target=arm-rtems --prefix=/opt/rtems
> --disable-rtems-inlines --enable-multiprocessing --enable-cxx
> --enable-rdbg --enable-maintainer-mode --disable-tests
> --enable-networking --enable-posix --enable-itron --disable-ada
> --disable-expada --enable-multilib
> + Bare BSP - example configure command
> ../current/configure --target=m68k-rtems --prefix=/opt/rtems
> --disable-rtems-inlines --disable-multiprocessing --enable-cxx
> --disable-expada --enable-rtemsbsp=bare
> --enable-bare-cpu-model=m5200     --enable-bare-cpu-cflags=-m5200
> The first doesn't build anything out of libbsp or libcpu.  The 2nd
> includes libcpu
> but not libbsp.  That will at least let you incrementally verify what is
> correct.
> > Any other ideas?
> Not without more information.  A log file might help.
> > David Dudley
> > On Friday 14 March 2003 12:09, Joel Sherrill wrote:
> > > David Dudley wrote:
> > > > I've run into a little problem setting up the libbsp/libcpu directory
> > > > structures for the AVR chip.
> > > > I defined a structure like this (which is a mirror of the structure
> > > > of the 'sh' directory):
> > > > libbsp
> > > >   + avr
> > > >       + DL16  (our particular board name)
> > > > libcpu
> > > >   + avr
> > > >        + ATmega128  (chip on the board)
> > > > Inside the ATmega128 directory I have the drivers for the console,
> > > > clock, rtc, etc....
> > > > Inside the DL16 directory I have the drivers for our specific board
> > > > implementation.
> > > > The bootstrap program runs with out any errors, and builds the links
> > > > into the avr directories.
> > > > OK, now when you do a configure, things go fine.  No errors or
> > > > anything else. When you run make however, the make starts building
> > > > the package, making the directories and copying files around, and
> > > > eventually gets to the libbsp and libcpu directories.  The libbsp
> > > > directory looks like its defined OK, and gets copies of the stuff
> > > > from the avr/DL16 directory, however, when the make moves to the
> > > > libcpu directory, it creates a directory called ATmega128 (right?),
> > > > and then tries to do a preinstall on the DL16 subdirector, which of
> > > > course, doesn't exist.
> > > > Whats wrong?  I have looked and looked, and I've built the directory
> > > > structure and configure.ac files in what it looks like is the right
> > > > form.
> > > Without looking at source, I would say that your RTEMS_CPU_MODEL is set
> > > to the
> > > name of the BSP (DL16) not the same of the CPU model (ATmeage128).
> > > Doublecheck
> > > the dl16.cfg file in make/custom.
> > > > Also, under the libbsp/avr directory, is it OK to have just our board
> > > > name directly at that level, or wouldn't it be better to list it as a
> > > > subdirectory of the company name (such as "StarBlade/DL16")?
> > > It might make a nice organizational aid but since no one has ever tried
> > > doing
> > > that I am prone to guess that something will depend upon libbsp/CPU/BSP
> > > being
> > > the structure.  So far, putting BSPs into CPU subdirectories has
> > > prevented
> > > clutter.  If you want, call the BSP starblade_dl16 and have the best of
> > > both
> > > worlds.  A more unique name and no worries of a subdirectory.
> > > > David Dudley
