CD build with ACE problems
Mon Mar 17 15:14:21 UTC 2003
Jack Cawkwell wrote:
> Hi,
> I am trying to build ACE under rtems, but I have problems.
> The first file that is compiled reports an error because
> clockid_t is not defined. Is this a common compilation
> problem with an obvious solution? It appears to me that the
> compiler gets into a state where it can nolonger parse
> legal code in :
> /opt/rtems/i386-rtems/include/sys/types.h circa line 245
> if I add
>         typedef anything int;
> before the offending line:
>         typedef _CLOCKID_T clockid_t;
> it fails on the added line, which should compile just about anywhere?
> i386-rtems-g++ and
> i386-rtems-cpp newlib-1.11.0-20030203 2
> I am using ACE version 5.3, the latest stable, it is much more
> recent that the 5.1.14 that was previously compiled.
> Any ideas? Jack
This usually indicates that the C library and RTEMS are out of sync.
It used to occur when transitioning from a 4.5.0 toolset to a
snapshot one.  Are you sure about which version of the tools you
are using?
--joel
