PPP and console driver questions
Thomas Doerfler Thomas.Doerfler at imd-systems.de
Thu Mar 20 07:42:21 UTC 2003
Hello,
this bug has been detected a year ago, a patch is
available... Have a look at
www.rtems.com/cgi-bin/gnatsweb.pl
login: guest
password: guest
look at PR162
wkr,
	Thomas.
> Questions about RTEMS PPP and the interrupt-driven console code for the
> Coldfire mcu in mcfuart.c:
> 1. The pppstart() function in ppp_tty.c calls the termios write callback
> function, in the console driver, with a buffer pointer and string
> length. The write function in the driver copies the pointer and uses the
> queue in place. There appears to be no feedback to prevent pppstart from
> calling the write function again before the characters are dequeued,
> thus moving the pointers and skipping part of the queue. It also appears
> that pppstart could overwrite the data in the buffer before the
> interrupt dequeues the previous packet.
> Do I understand this correctly? If so, which part of this code needs to
> be corrected - the console driver?
> 2. The console transmit interrupt calls rtems_termios_dequeue_characters
> with the buffer length that was passed into it by the previous write
> callback. That would mean the dequeue_characters function would
> eventually be limited to the smallest packet size previously
> transmitted, except that the function ignores the length parameter when
> it calls the PPP line discipline function.
> Does the console driver need to handle these conditions? It appears that
> it should copy the queued transmit characters into it's own buffer, and
> that buffer must be large enough to handle anything the pppstart
> function will throw at it. Or is it adequate, acceptable, or preferable
> to block in the console write function until the queue is empty?
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler           Herbststrasse 8
D-82178 Puchheim          Germany
email:    Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd-
systems.de/pgp_keys.htm
