(Fwd) Re: DOSFS bug fixes, IDE drivers and sample released
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Thu Mar 20 15:01:19 UTC 2003
Am Mit, 2003-03-19 um 23.42 schrieb Angelo Fraietta:
> This did not work for me. Doing the autoreconf from both the samples
> directory and the RTEMS root directory still did not produce the
> required sample. I did not get an error from either directory, but
> both were very quick.
> If I attempt the bootstrap method, I get the error
> RTEMS requires automake version 1.7.2
The snapshot requires 1.7.2.
> I have automake version 1.7.3
Using automake-1.7.3 is fine, but you'll have to update the bootstrap
script from the rtems-4-6-branch on RTEMS cvs if wanting to use it.
Ralf
