(Fwd) Re: DOSFS bug fixes, IDE drivers and sample released
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Fri Mar 21 08:14:51 UTC 2003
Hello,
> I got the program working and it worked fine with my flash disk.
> I did, however, have to type my filenames in UPPER CASE. I don't know
> whether this is something peculiar with the DIMMPC flash IDE or not.
I am glad things are working for you now. The upper case
matter is a bit strange. Per definition, DOS filenames are
case insensitive. They are stored in upercase in the dorectory
but I am sure I open my files with a lowercase filename given
and the functions definitively find the right file and open
and read/write it.
Could this be a problem on the MAC side?
I don't know, if the patches will make it into the next
release, we had a discussion with Joel about it. I think they
will not break anything that was working without the
patches...
wkr,
Thomas.
> I also modified so I wrote a binary stream from 0x00 to 0xFF and tested
> that it was uncorrupted. That worked fine too.
> So effectively, this is working fine for me.
> Do you know whether this will be included in the next snapshot?
> Thomas Doerfler wrote:
> >Hello,
> >no it has nothing to do with ada, it is a web-
> >based bug tracking system. Just try it out,
> >login/password is guest/guest...
> >wkr,
> > Thomas.
> >>Is the gnats system only ada? I am using C/C++, so will I be able to use
> >>these?
> >>>Hello Angelo,
> >>>the "sample" program is located in the patch filed in the gnat
> >>>system as PR369. So if you go to
> >>>http://www.oarcorp.com/cgi-bin/gnatsweb.pl
> >>>and inspect PR369 and download/apply the patch and then look
> >>>into c/src/tests/samples/fileio, you will see the sample
> >>>application.
> >>>BTW, you will also need PR368 and PR367 to get everything
> >>>running (these PRs contain modifications for the DOSFS code
> >>>and added drivers for PC386 and MBX8xx).
> >>>wkr,
> >>> Thomas.
> >>Angelo Fraietta
> >>PO Box 859
> >>Hamilton NSW 2303
> >>Home Page
> >>http://www.users.bigpond.com/angelo_f/
> >>There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
> >>There are those who seek knowledge to be known by others - that is VANITY
> >>There are those who seek knowledge in order to serve - that is LOVE
> >> Bernard of Clairvaux (1090 - 1153)
> >IMD Ingenieurbuero fuer Microcomputertechnik
> >Thomas Doerfler Herbststrasse 8
> >D-82178 Puchheim Germany
> >email: Thomas.Doerfler at imd-systems.de
> >PGP public key available at: http://www.imd-
> >systems.de/pgp_keys.htm
> Angelo Fraietta
> PO Box 859
> Hamilton NSW 2303
> Home Page
