(Fwd) Re: DOSFS bug fixes, IDE drivers and sample released
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Mar 21 13:01:23 UTC 2003
Angelo Fraietta wrote:
> I got the program working and it worked fine with my flash disk.
> I did, however, have to type my filenames in UPPER CASE. I don't know
> whether this is something peculiar with the DIMMPC flash IDE or not.
> I also modified so I wrote a binary stream from 0x00 to 0xFF and
> tested that it was uncorrupted. That worked fine too.
> So effectively, this is working fine for me.
> Do you know whether this will be included in the next snapshot?
Are you specifically referring to the test application or some
particular patch set?
> Thomas Doerfler wrote:
>> Hello,
>> no it has nothing to do with ada, it is a web-
>> based bug tracking system. Just try it out, login/password is
>> guest/guest...
>> wkr,
>> Thomas.
>>> Is the gnats system only ada? I am using C/C++, so will I be able to
>>> use these?
>>>> Hello Angelo,
>>>> the "sample" program is located in the patch filed in the gnat
>>>> system as PR369. So if you go to
>>>> http://www.oarcorp.com/cgi-bin/gnatsweb.pl
>>>> and inspect PR369 and download/apply the patch and then look into
>>>> c/src/tests/samples/fileio, you will see the sample application.
>>>> BTW, you will also need PR368 and PR367 to get everything running
>>>> (these PRs contain modifications for the DOSFS code and added
>>>> drivers for PC386 and MBX8xx).
>>>> wkr,
>>>> Thomas.
>>> Angelo Fraietta
>>> PO Box 859
>>> Hamilton NSW 2303
>>> Home Page
>>> http://www.users.bigpond.com/angelo_f/
>>> There are those who seek knowledge for the sake of knowledge - that
>>> is CURIOSITY
>>> There are those who seek knowledge to be known by others - that is
>>> VANITY
>>> There are those who seek knowledge in order to serve - that is LOVE
>>> Bernard of Clairvaux (1090 - 1153)
>> IMD Ingenieurbuero fuer Microcomputertechnik
>> Thomas Doerfler Herbststrasse 8
>> D-82178 Puchheim Germany
>> email: Thomas.Doerfler at imd-systems.de
>> PGP public key available at: http://www.imd-
>> systems.de/pgp_keys.htm
