ACE TAO RTEMS build
Jack Cawkwell
J.Cawkwell at open.ac.uk
Tue Mar 25 08:01:02 UTC 2003
Phil,
Thanks for this. Do you have the C file that drives these tests?
Is it tests/rtems_init.c . I anticipate that I will have to create
a version of rtems_init.c for each test, and then link then to the
rest of rtems, add netboot parts, then load onto the board
(in my case a PC104 i386).
Jack
Phil Torre <ptorre at zetron.com> writes:
>Gents,
>For what it's worth, I spent some time getting ACE working with RTEMS
>before we lost political support for using a cross-platform abstraction
>layer for RTEMS and ms windows. I was using rtems-ss-20020628 and
>ACE (without TAO) from their CVS server circa 11/21/2002. Attached is
>a summary my luck at getting the tests in the ACE test suite to run.
>I made one tweak to the POSIX key destructor behavior in RTEMS, but
>IIRC most of the changes required were to the test programs themselves
>(trimming resource requirements so they would run on our MPC860 board).
>Best regards,
>-Phil
