inw/outw on PowerPC in rtems
gregory.menke at gsfc.nasa.gov
Tue Mar 25 14:29:21 UTC 2003
Till Straumann writes:
> gregory.menke at gsfc.nasa.gov wrote:
> >I'm putting together a 3c59x PCI driver for RTEMS, its at a point
> >where I'm testing it now- but I'm having trouble accessing the card.
> >I have the PCI side under control, but the chipset exists in io space,
> >and the inw/outw functions don't seem to be doing the right things.
> inw accesses ISA I/O space. Unless your
> BSP uses the same base address for ISA and PCI I/O space (plus: the
> firmware/BSP
> has to configure your card's base address consistently - PreP and CHRP
> should
> probably work), you'll have a problem.
> I usually prefer in_le32() which gives you more control over the base
> address.
> Using in_le32() with a BSP defined base address makes your driver easier to
> use on different BSPs.
> The respective macros and inlines are defined in
> libcpu/powerpc/shared/include/io.h
As expected, the problem was located between keyboard and chair- I
wasn't masking off the low bits coming from the base address register.
On PCI IO spaces, bit 0 is set, so it was skewing the address. All is
fine now...
Gregm
