OK, so Which bsd and which driver?
gregory.menke at gsfc.nasa.gov
Wed Mar 26 18:08:13 UTC 2003
Camilo Alejandro Arboleda writes:
> If you think it is easier to port linux driver, you can try what we did
> when we needed a driver for M-Systems DiskOnChip hardware: Ask the
> author for permision to redistribute it with the exception.
> Most people don't care about the exact license terms if you act in an
> ethical way and keep the software free (open source).
I think its unlikely that something like the Linux 3com driver is
going to change its licensing terms at this point. Even so, if I had
the code actually working, something like that might be a way out. I
hadn't gotten over the debugging hump, as I was only nearing the
completion of moving the Linux code into RTEMS and fixing the textual
differences. The adaptation of the runtime & interrupt models to
RTEMS was still to come.
The bsd code is closer to RTEMS anyhow, I suspect porting that will
take less time in any case.
Gregm
