mp application for powerpc-psim does not work!
Bert
doclzs at 21cn.com
Thu May 1 15:38:05 UTC 2003
Hi, i have installed RTEMS for powerpc-psim,
and configured it with the option
--enable-multiprocessing. i want to run a
mp application with two nodes on psim,
but failed. Here is what i have done:
# powerpc-rtems-gdb base_mp-node1.exe
(gdb) tar sim -f fsim
(gdb) load
(gdb) run
Starting program:/tmp/base_mp/node1/base_mp-node1.exe
core_find_mapping() - access to unmaped address, attach a default map to handle this - addr=0xc0000000 nr_bytes=0x4 processor=0x40250008 cia=0x16ca0
# powerpc-rtems-gdb base_mp-node2.exe
(gdb) load
(gdb) run
Starting program:/tmp/base_mp/node2/base_mp-node2.exe
core_find_mapping() - access to unmaped address, attach a default map to handle this - addr=0xc0000040 nr_bytes=0x4 processor=0x40250008 cia=0x2184
and what in the file "fsim" is as following:
/#address-cells 2
/openprom/options/oea-memory-size 8388608
Is there anything i have done wrong? What should i do to make the application work perfect?
Thanks in advance !!!
Ãâ·ÑÍæÆ»¹ûÅÉÍøÂçÓÎÏ·£¬ÓÃ21CNÓÊÏä×¢²áËÍ²ÊÆÁÊÖ»ú¼°¼ÛÖµÊýÊ®ÍòµÄ¾«ÃÀ½±Æ·
http://www.appie.com.cn
Áô¸øÕŹúÈÙ×î°®µÄ˵»°
http://sms.21cn.com/leslie/
½¡¿µÐÔ¹ÛÄîÏíÊÜÃÀÃîµÄʱ¿Ì
http://sms.21cn.com/sexxy.jsp
21CN²ÊÐÅÓÊ£¬ÉùÉ«²ÊÐÅ£¬×ÔÓÉÊÕ·¢
http://mail.21cn.com/huodong/0304/
ÐÂÔöHTML±à¼Æ÷£¬ÁîÓʼþ¸ü³öÉ«
http://mail.21cn.com/bijiao/02.html
