4.6.0pre3 available
Derick Hammond derick at perkinstechnologies.com.au
Thu May 1 23:03:55 UTC 2003
Hi Chris, Joel:
I installed the m68k-rtems-c++-gcc3.2.2newlib1.11.0-2 RPM, so I could do
the same configure command as what Chris wrote below.
I can see that the -O2 option is passed for every cpu variant except for
the default (ie. no -m options), which I find a little strange.
Anyway, I hope this information helps.
Regards,
Derick Hammond
Chris Johns wrote:
>Derick Hammond wrote:
>>Thank you for letting me know about the -O2 option.
>>I compiled the same file with the -O2 option included in the command line
>>and it worked.
>I wonder if 3.2.3 get the problem with-out -O2. I will try tomorrow.
>All I used to build was:
>   $ ../rtems-4.6.0pre3/configure --target=m68k-rtems --prefix=/opt/rtems \
>     --enable-multilib --enable-doc \
>     --enable-cxx --disable-tests \
>     --enable-posix --disable-itron --enable-networking
>   $ make RTEMS_BSP="" all install
>I do not know where my -O2 option is coming from and why you did not see it.
>  Chris Johns, cjohns at cybertec.com.au
