4.6.0pre3 available
Chris Johns cjohns at cybertec.com.au
Thu May 1 13:04:41 UTC 2003
Derick Hammond wrote:
> Thank you for letting me know about the -O2 option.
> I compiled the same file with the -O2 option included in the command
> line and it worked.
I wonder if 3.2.3 get the problem with-out -O2. I will try tomorrow.
All I used to build was:
   $ ../rtems-4.6.0pre3/configure --target=m68k-rtems --prefix=/opt/rtems \
     --enable-multilib --enable-doc \
     --enable-cxx --disable-tests \
     --enable-posix --disable-itron --enable-networking
   $ make RTEMS_BSP="" all install
I do not know where my -O2 option is coming from and why you did not see it.
  Chris Johns, cjohns at cybertec.com.au
