Reading from physical addresses..
Eric Valette eric.valette at free.fr
Fri May 2 19:04:28 UTC 2003
Aaron J. Grier wrote:
> RTEMS is designed for use in embedded environments which may or may not
> have memory protection available, and assumes a flat memory map.  on
> systems with MMU hardware, some minimal memory protection may be
> applied, but there's no virtual memory or per-process memory spaces on
> any RTEMS targets as far as I am aware.
> I run on MMU-less m68k hardware; perhaps someone else here with more
> advanced processor can volunteer more specifics?  ;)
Well just to give a small different perspective, I will put my two
cents. I think we can say this a little bit differently : RTEMS code
assume a 1-1 physical/virtual memory mapping and no protection across
kernel/application space. There are a couple of CPU where MMU is enabled
with a 1-1 mapping :
	1) IX86 because there is no way to disable caching selectively and you
cannot turn the cache entirely off for performance reasons but you need
to disable it for memory mapped via PCI address space for ethernet
drivers for example,
	2) On some processor you cannot turn the cache on without the MMU
    __
   /  `                   	Eric Valette
  /--   __  o _.          	6 rue Paul Le Flem
(___, / (_(_(__         	35740 Pace
Tel: +33 (0)2 99 85 26 76	Fax: +33 (0)2 99 85 26 76
E-mail: eric.valette at free.fr
