4.6.0pre3 available
Derick Hammond derick at perkinstechnologies.com.au
Thu May 1 13:06:53 UTC 2003
Hi Chris:
Thank you for letting me know about the -O2 option.
I compiled the same file with the -O2 option included in the command line
and it worked.
I then added the -O2 option to the CFLAGS variable in:
         ~/build-m68k-rtems/m68k-rtems/cpukit/libmisc/capture/Makefile
And successfully completed the build. I had a quick look at:
         ~/rtems/cpukit/libmisc/capture/Makefile.am
But didn't see anything obviously wrong.
Thanks for your quick response.
Regards,
Derick Hammond
Chris Johns wrote:
>Derick Hammond wrote:
>>Hi Chris:
>>I have tried the following, as I too wish to build my BSP outside of the
>>RTEMS source tree:
>>$ ../rtems-4.6.0pre3/configure --enable-multilib
>>--prefix=/tmp/test-m68k-rtems --target=m68k-rtems
>>$ make RTEMS_BSP="" all
>>But I had the following error during the make process:
>>m68k-rtems-gcc --pipe -DPACKAGE_NAME=\"rtems-cpukit-libmisc\"
>>-DPACKAGE_TARNAME=\"rtems-cpukit-libmisc\"
>>-DPACKAGE_VERSION=\"4.6.0pre3\" -DPACKAGE_STRING=\"rtems-cpukit-libmisc\
>>4.6.0pre3\" -DPACKAGE_BUGREPORT=\"rtems-bugs at OARcorp.com\"    -isystem
>>../../../lib/include        -g -Wall  -o o-optimize/capture-cli.o -c
>>../../../../../rtems-4.6.0pre3/cpukit/libmisc/capture/capture-cli.c
>>../../../../../rtems-4.6.0pre3/cpukit/libmisc/capture/capture-cli.c: In
>>function `rtems_capture_task_time':
>>../../../../../rtems-4.6.0pre3/cpukit/libmisc/capture/capture-cli.c:1468:
>This is similar to the error reported in PR292 in the RTEMS bug database,
>but the line number has moved and the target was the cpu32. This is the
>default m68k variant which I think is the 68020.
>What is strange is I cannot see the -O2 option. I noticed the compiler's
>standard build optimisation level is now 2, that is I had -O2 as a gcc
>option. The PR292 has no -O as well.
>>I note that there is a difference in the tools you used to compile RTEMS.
>>Is there a reason to use gcc-3.2.3 over gcc-3.2.2?
>GCC 3.2.3 may help, but I think we should find out what is happening with
>the -O option first.
>>Any hints or tips to diagnose this problem would be greatly appreciated.
>>System:
>>Redhat 7.3 - kernel-2.4.18-26.7.x
>Should be fine.
>>RTEMS Packages installed:
>>autoconf-rtems-2.57-1
>I have just 2.57 but this should matter.
>>automake-rtems-1.7.2-1
>I have 1.7.4, but this should not be a problem.
>>rtems-base-binutils-2.13.2.1-2
>>m68k-rtems-binutils-2.13.2.1-2
>I have these.
>>rtems-base-gcc-gcc3.2.2newlib1.11.0-2
>>m68k-rtems-gcc-gcc3.2.2newlib1.11.0-2
>I have gcc 3.2.3 and newlib 1.11.0.
>  Chris Johns, cjohns at cybertec.com.au
