Rif: Re: picture with SIS
    silverio.di at qem.it
    Fri May 30 13:35:43 UTC 2003
I guess you have to convert  your BMP file to an C data file (example an
array of byte called SIS_BMP),
then you have to insert this file in your project. At this point you can
set the pointer of BMP object to your
SIS_BMP array.
                      ktari jalel
                      <rtos_jalel at yahoo        Per:      rtems-users at oarcorp.com
                      .fr>                     Cc:
                                               Oggetto:  Re: picture with SIS
                      30/05/03 15.33
hello Mr joel
the problem that i can run this program with out RTEMS
but the library that i use have some instruction to load picture
Is it possible to load the picture with spar-rtems-ld ,and after i use a
pointer to the adress of my picture in my program, so i can use SIS
thinks
Do You Yahoo!? -- Une adresse @yahoo.fr gratuite et en français !
Testez le nouveau Yahoo! Mail
