In picoTK, for example there is a program, ppmripper.c, which read a PPM
file and create a C file
with a data array containing the PPM bitmap values....
http://picotk.sourceforge.net/
ktari jalel
<rtos_jalel at yahoo Per: rtems-users at oarcorp.com
.fr> Cc:
Oggetto: Re: picture with SIS
30/05/03 15.33
hello Mr joel
the problem that i can run this program with out RTEMS
but the library that i use have some instruction to load picture
Is it possible to load the picture with spar-rtems-ld ,and after i use a
pointer to the adress of my picture in my program, so i can use SIS
thinks
Do You Yahoo!? -- Une adresse @yahoo.fr gratuite et en français !
Testez le nouveau Yahoo! Mail
