m68302 boot problem - newbie!!!
Nicco
pigeon.nicolas at wanadoo.fr
Thu May 8 21:05:49 UTC 2003
I don't think this a timer problem because I just deleted the 3 suspect
lines before the problematic JSR instruction, and this problem seems
almost solved, the board contiues to boot. But I still don't know the
purpose of these instructions... Anyway, thank you very much for your
reply !!
-----Original Message-----
From: Steven Grunza [mailto:steven_grunza at ieee.org]
Sent: mercredi 7 mai 2003 16:48
To: pigeon.nicolas at wanadoo.fr
Subject: Re: m68302 boot problem - newbie!!!
This is just a shot in the dark but does the 68302 have a watchdog
timer? If it does is it timing out?
Another thing I've seen happen is a periodic timer timing out before the
ISR that handles it is installed. I've been bit with this on PowerPC
with
the DECrementer.
PS
I haven't used the 68302 but thought I'd contribute my USD 0.02
At 02:15 PM 5/7/2003 +0200, you wrote:
>Hi,
>I'm working on a home made board made of a m68302, 512 ko RAM on CS1
>and 1
>Mo Eprom on CS0, and I have two problems I'm unable to solve...
>I (try to) use RedHat 7.3 and RTEMS 4.5.0, and my work is based on the
>ods68302 BSP which seems very close to mine. And here's my first
problem:
>everything boots fine until the 68302 reaches the code needed to copy
the
>.data section into RAM. Indeed, the origin and destination addresses
are
>the same, and located in the Eprom. I guess it's a linker problem, but
the
>linker script seems OK (I did not modify it), and I can't locate the
>problem. Does anybody have a little idea or suggestion please? This
work
>is important to me because I'm still a student and I may not be
graduated
>if I fail my internship...
>Then the second problem (the first one does not make the card hang, and
>it's still working... but not for a long time :-(): when the 68302
reaches
>a JSR instruction to jump to the "boot_phase_3" subroutine, it indeed
>jumps at the right place, but it only reads the first byte of the next
>instruction (which is a JSR too), and then the address bus goes to
FFFFF,
>and that's it! Here's the assembly code just before and after the
problem:
> movel %d0,_stack_init |do=0 here,
and
> _stack_init is at the end of .bss
> movew #0x3700, %sr |supervisor
mode,
> all interrupts off
> movel %d0, %a7 |set
master
> stack pointer
> movel %d0, %a6 |set base
pointer
> jsr boot_phase_3
> The jump is OK, at the right place, where there is
> jsr debug_port_banner
>This instruction is not even read until its end (3 bytes long, only
the
>first is read), and the adress bus goes to FFFFF. The 68302 doesn't
even
>try to go to an exception vector...
>I would really appreciate any help or ideas, it would save me!!
>Thanks
"Unix is user friendly, it's just | Steven Grunza
particular about with whom it | voice: (856) 787 - 2759
makes friends." | fax: (856) 866 - 2033
- Unknown | mailto:steven_grunza at ieee.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20030508/70f3b1ce/attachment-0001.html>
