rtems-4.6pre4 building first time
Sat Nov 1 11:35:39 UTC 2003
Ralf Corsepius wrote:
>On Sat, 2003-11-01 at 06:40, Chris Sparks wrote:
>>Hi everyone,
>>I am building RTEMS for the first time and I am unsure which files I'll
>>need to support an Ada system. The document says:
>Which version of RTEMS are you trying to use.
>Which document recommends to using these tools? This is utterly outdated
>and should be fixed ASAP.
THis looks like what may have been in the Ada Getting Started which I
have finally
dropped from the 4.6 documentation set but it has been marked as
"obsolete and
needs to be merged into the main getting started" for months if not at
least a year.
>>gcc 2.8.1
>>gnat 3.13p
>>binutils 2.10
>>newlib 1.8.2
>>rtems-4.5.1.tgz
>>hello_world_ada.tgz
>>c_build_scripts-4.5.1.tgz
>>binutils-2.10-rtems-gnat-3.13p-20001107.diff
>>newlib-1.8.2-rtems-20000606.diff.gz
>>gcc-2.8.1-rtems-gnat-3.13p-20000429.diff.gz
>>gnat-3.13p-rtems-20000829.diff
>>I know some of these aren't right.
>I don't understand what you are trying to say. They seem to reflect the
>status having been "right" 3 years ago and they still apply to outdated
>(I prefer: obsolete) versions of RTEMS
>> Can someone please help clear up what
>>I need?
>Please tell us which version of RTEMS you want to use.
>>This is quite frustrating since I have a modem download and it isn't fast.
>Ralf
