rtems-4.6pre4 building first time
Chris Sparks mrada at catalina-inter.net
Sat Nov 1 17:34:05 UTC 2003
Hi everyone,
Well I downloaded 4.6 pre 5 stuff, or what I thought I needed.  Let me
list out what I have:
autoconf-2.57.tar.bz2
automake-1.7.2.tar.bz2
binutils-2.13.2.1-rtems-20030901.diff
binutils-2.13.2.1.tar.bz2
examples-4.6.0pre5.tar.bz2
gcc-2.8.1.tar.gz
gcc-3.2.3-rtems-20030826.diff
gcc-3.2.3.tar.bz2
gdb-5.2-rtems-base-20030211.diff
gdb-5.2-rtems-cg-20030211.diff
gdb-5.2-rtems-rdbg-20030211.diff
gdb-5.2.tar.gz
network-demos-4.6.0pre5.tar.bz2
newlib-1.11.0-rtems-20030605.diff
newlib-1.11.0.tar.gz
rtems-4.6-i386-rtems-binutils-2.13.2.1-1.i686.rpm
rtems-4.6-i386-rtems-c++-gcc3.2.3newlib1.11.0-1.i686.rpm
rtems-4.6-i386-rtems-gcc-gcc3.2.3newlib1.11.0-1.i686.rpm
rtems-4.6-i386-rtems-gdb-5.2-1.i686.rpm
rtems-4.6-i386-rtems-gnat-gcc3.2.3newlib1.11.0-1.i686.rpm
rtems-4.6-rtems-base-binutils-2.13.2.1-1.i386.rpm
rtems-4.6-rtems-base-gcc-gcc3.2.3newlib1.11.0-1.i686.rpm
rtems-4.6-rtems-base-gdb-5.2-1.i686.rpm
rtems-4.6-rtems-base-gnat-gcc3.2.3newlib1.11.0-1.i686.rpm
rtems-4.6.0pre4-4.6.0pre5.diff.bz2
I didn't download 4.6 pre 5 bz2 since I can patch up form pre 4 which I
already have.  So am I going to have problems doing Ada since the
documentation is no longer current?  Any tips?
Thanks,
