Question to OAR
Ralf Corsepius corsepiu at faw.uni-ulm.de
Mon Nov 17 21:36:55 UTC 2003
On Mon, 2003-11-17 at 21:18, Dieter Schaefer wrote:
> On 11 Nov 2003 at 18:22, Dieter Schaefer wrote:
> > Hello,
> > did the combination
> >   powerpc-rtems/eth_comm
> > build Ok on your site under CygWin?
> > (rtems-4.6.0pre5 and associated tool-chain for CygWin)
> > If yes, could you pls tell me your CygWin version and Operating
> > System?
> > If not, could you try to get it to work?
> > Thanks
> > Dieter Schaefer
> unfortunately, I got no answer to my question.
> My conclusion is that this combination was never tested.
> Digging into that problem myself, I found the following:
> * target=m68k-rtems, rtemsbsp=mcf5206elite
> * target=arm-rtems, rtemsbsp=edb7312 + vegaplus
> builds Ok, including tests
> * powerpc-rtems, rtemsbsp=eth_comm + mbx8xx
> fails to build.
> Now, guess why ... If you need a hint, don't hesitate to ask ...
> Of course, It's fixed now.
And ... will you tell us?
RTEMS is an OpenSource project and if you want it to be improved
collaborate and contribute, or stay away.
Ralf
