rtems-4.6pre5 building first time WITH Ada
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Mon Nov 10 16:23:32 UTC 2003
On Mon, 2003-11-10 at 14:26, Paul Evans wrote:
> Hi,
> That's odd that you have this problem with RH7 [Ed: Chris has pointed out
> to me that he has RH7] My previous advice assumed you wouldn't
> otherwise need glibc, as there are still quite a few libc5 systems
> around.
libc5 is obsolete, dead and unmaintained since some point in 1998. All
major Linux distros switched to using glibc2/libc6 for several years
So, though using such an ancient system as a less important server might
still make some sense, using such system as a developer's machine
doesn't (... unless working in a Linux-museum :-)).
You won't even be able to build and compile most modern software. AFAIK,
GCC is about to abandon libc5 in their next release, gcc-3.4.
Ralf
