UDP packet not sent (LEON+OpenCores NIC)
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Nov 12 11:35:16 UTC 2003
Rolf Schroedter wrote:
> Joel Sherrill wrote:
>> Are you trying to run at 100 Mbits? Jiri Gaisler mentioned to me
>> that the OpenCores
>> NIC is not 100% perfect at 100 Mbits.
> The Linux-PC NIC is 10 Mbits.
> Therefore I assume that the OpenCores NIC runs also at 10 Mbits.
> The communication is stable until the first 960 byte packet is
> written to the IP stack.
OK. Just a thought. Jiri did run ttcp on the nic before submitting it so
it was stable in his configuration at 10 Mbits.
Given the custom nature of the LEON+NIC, it could be hardware or
something as simple as a stack size. Somehow I doubt a basic driver
but given that it worked for Jiri.
> Rolf.
> Rolf Schroedter
> German Aerospace Center
> Institute of Space Sensor Technology and Planetary Exploration
> D-12489 Berlin, Rutherfordstrasse 2
> Tel/Fax: (+49) (30) 67055-416/384
> Email: Rolf.Schroedter at dlr.de
