UDP packet not sent
gregory.menke at gsfc.nasa.gov
Wed Nov 12 16:26:49 UTC 2003
Rolf Schroedter writes:
> gregory.menke at gsfc.nasa.gov wrote:
> > Ah, I see- thats a different problem. In your udpclose function, you
> > call the various rtems_ info functions. If you call them before and
> > after the packets are lost, are the lost packets being properly
> > counted?
> > Its not inconceivable theres a bug in the driver, but I would not
> > suspect one in the IP stack itself.
> Hallo Gregory,
> unfortunately I'm not able to reply to you from home.
> Your gsfcrelay4.gsfc.nasa.gov blocks my web.de
Our email system does very strange things sometimes, sorry about that.
Unless I'm mistaken, the log doesn't show the packet tx count at the
driver- which I think is what we need for a hint as to where the
packets are being lost. You have the tx count at the application
layer- so thats what the driver's count will compare to.
Given your simple topology, I'm suspecting the driver. Could you
write a program to exercise all packet lengths between say ~100 to
~1450, so we can see if there are periodic trouble spots?
I'm in the middle of the run-up to a major deliverable, so I can't
devote much time this week. Next week will be a big relief... and
I'll be happy to help then. :)
Gregm
