cpukit Libraries install problem
Cedric Aubert cedric_aubert at yahoo.fr
Fri Oct 3 10:16:18 UTC 2003
Hi all,
I have some trouble to use the libmisc or other
cpukit libraries in my user application. (Can't link)
So I search in my bsp lib and rtems cpu shared lib and
don't found libmisc.a but I found it in my build
directory.
I have /opt/rtems/mybsp (I move my prefix at configure
here)
I have build in /opt/rtems/build (it's were I found
the
lib).
I should make a very very begimmer mistake :-)
Because I try to find the solution on the ml archive,
I don't found anything.
If anyone could explain me how to correctly install
those cpukit libraries.
I link with -B /opt/rtems/m68k-rtems/lib
-B /opt/rtems/bsp-cpu2000/m68k-rtems/cpu2000/lib
-B /opt/rtems/bsp-cpu2000/m68k-rtems/lib
But libmisc.a was found in
./build-m68k/m68k-rtems/cpukit/libmisc/wrapup/o-optimize/libmisc.a
./build-m68k/m68k-rtems/m68000/cpukit/libmisc/wrapup/o-optimize/libmisc.a
Thanks a lot
Cedric
__________________________________
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
http://shopping.yahoo.com
