cpukit Libraries install problem
Fri Oct 3 11:15:03 UTC 2003
Cedric Aubert wrote:
>Hi all,
>I have some trouble to use the libmisc or other
>cpukit libraries in my user application. (Can't link)
>So I search in my bsp lib and rtems cpu shared lib and
>don't found libmisc.a but I found it in my build
>directory.
>I have /opt/rtems/mybsp (I move my prefix at configure
>here)
>I have build in /opt/rtems/build (it's were I found
>the
>lib).
>I should make a very very begimmer mistake :-)
>Because I try to find the solution on the ml archive,
>I don't found anything.
>If anyone could explain me how to correctly install
>those cpukit libraries.
>I link with -B /opt/rtems/m68k-rtems/lib
>-B /opt/rtems/bsp-cpu2000/m68k-rtems/cpu2000/lib
>-B /opt/rtems/bsp-cpu2000/m68k-rtems/lib
>But libmisc.a was found in
>./build-m68k/m68k-rtems/cpukit/libmisc/wrapup/o-optimize/libmisc.a
>./build-m68k/m68k-rtems/m68000/cpukit/libmisc/wrapup/o-optimize/libmisc.a
Those are just intermediate libraries that are bundled together to make
the single library
and large librtemcpu.a.
>Thanks a lot
>Cedric
>__________________________________
>Do you Yahoo!?
>The New Yahoo! Shopping - with improved product search
>http://shopping.yahoo.com
