More heap corruption / allocator lock problems
Till Straumann
strauman at SLAC.Stanford.EDU
Wed Oct 8 20:15:46 UTC 2003
I implemented a quick workaround for this which can simply
be linked to an existing application using the
-Wl,--wrap,free
gcc/linker option. See attached file
-- T.
Till Straumann wrote:
> Hi all.
> Paranoia pays off.
> Today, (thanks to the paranoia check added to PR#504)
> I found one more place where a CORE_mutex (the allocator
> lock) is acquired from a dispatching-disabled code section:
> The task-variable destructor hook (used e.g. by the rtems_shell
> and 'libc userenv')!
> Since it is run as part of a user extension's delete
> hook/callback, the task variable destructor runs with
> dispatching disabled :-(
> Two solutions come to my mind:
> a) memory that is going to be released by a task-variable
> destructor must be allocated from the workspace
> b) free could be enhanced:
> if 'free' is called while _Thread_Dispatch_disable_level > 0,
> it sends its pointer argument to a special "gc" thread which
> will eventually execute the real 'free'. The synchronization
> mechanism *must* be nonblocking, of course, to avoid the
> same kind of problem...
> While I feel that b) is 'hackish', it could certainly provide
> backwards compatibility...
> RFC
> -- Till
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20031008/745b044f/attachment.ksh>
