gcc/gdb testsuites on rtems and psim simulator
JP Bonn
rtemsmail at jpbonn.eioMAIL.com
Thu Oct 30 21:35:45 UTC 2003
I'm running the GDB and GCC testsuites on RTEMS and the PSIM simulator.
One problem I've run into is a lot of the tests end with "return 0;"
which just causes RTEMS to sit idle and the testsuite to fail that test.
The quick fix I did was to substitute "exit(0);". Is there a better
approach?
The best kept secret in e-mail.
http://eioMAIL.com
