RTEMS on Altera NIOS processor
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Oct 1 22:44:06 UTC 2003
Eric Norum wrote:
> Has anyone out there looked into the possibility of running RTEMS
> applications on a NIOS embedded (on a FPGA) processor?
It isn't in the main gcc tree but given that Altera has GNU tools
(nios-elf) which include a simulator,
it looks like a very doable port. The exception/interrupt model appears
quite straightforward.
Simple answer is that my 10 minute analysis says that if you aimed at a
port to the simulator
(and it supported some clock interrupt source), it would be on the
easier side of the port
effort scale.
> If nothing else, it already has a good project code-name (ROACH -
> RTEMS On A CHip)!
Nice name. :)
--joel
