cpukit Libraries install problem
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Fri Oct 3 12:05:34 UTC 2003
Hi Cederic,
> I want to use the termios_printk feature, witch is
> provided in the serdbg. I don't found it in my
> libmisc.a, even if I already found capture and untar
> for example.
> Any idea ?
I should have, because this code is from me ;-)
It was integrated into the source tree, but Joel experienced
some problems with the pc386 BSP some time ago, so maybe it is
not included into librtemscpu.a now.
I used it recently without problems, the easiest way to use it
for you would be to add its sources to your apllication make
environment.
Please be aware that the port you want to use with
termios_printk MUST be configured to work in polled mode (not
interrupt driven).
wkr,
Thomas.
> Thanks
> Cedric
> --- Thomas Doerfler <Thomas.Doerfler at imd-systems.de>
> wrote:
> > Hi Cederic,
> > the list of libs has been reduced in one of the
> > recent version steps, so the functions of
> > libmisc.a should now be included in librtemscpu.a
> > ( I think).
> > wkr,
> > Thomas.
> > > Hi all,
> > > I have some trouble to use the libmisc or other
> > > cpukit libraries in my user application. (Can't
> > link)
> > > So I search in my bsp lib and rtems cpu shared lib
> > and
> > > don't found libmisc.a but I found it in my build
> > > directory.
> > > I have /opt/rtems/mybsp (I move my prefix at
> > configure
> > > here)
> > > I have build in /opt/rtems/build (it's were I
> > found
> > > the
> > > lib).
> > > I should make a very very begimmer mistake :-)
> > > Because I try to find the solution on the ml
> > archive,
> > > I don't found anything.
> > > If anyone could explain me how to correctly
> > install
> > > those cpukit libraries.
> > > I link with -B /opt/rtems/m68k-rtems/lib
> > > -B /opt/rtems/bsp-cpu2000/m68k-rtems/cpu2000/lib
> > > -B /opt/rtems/bsp-cpu2000/m68k-rtems/lib
> > > But libmisc.a was found in
> ./build-m68k/m68k-rtems/cpukit/libmisc/wrapup/o-optimize/libmisc.a
> ./build-m68k/m68k-rtems/m68000/cpukit/libmisc/wrapup/o-optimize/libmisc.a
> > > Thanks a lot
> > > Cedric
> > > __________________________________
> > > Do you Yahoo!?
> > > The New Yahoo! Shopping - with improved product
> > search
> > > http://shopping.yahoo.com
> > IMD Ingenieurbuero fuer Microcomputertechnik
> > Thomas Doerfler Herbststrasse 8
> > D-82178 Puchheim Germany
> > email: Thomas.Doerfler at imd-systems.de
> > PGP public key available at: http://www.imd-
> > systems.de/pgp_keys.htm
> Do you Yahoo!?
> The New Yahoo! Shopping - with improved product search
